Editing Component Properties
The Properties panel allows you to edit the location and properties of a selected component in the 3D world.
If a selected component contains two or more sets of properties, each set will appear as a tab in the Properties panel.
  1. In the 3D world, select a component.
  2. In the Properties panel, edit one or more available properties. If a component contains tabs of properties, click a tab to display its properties, and then edit them.
If two or more components are selected, you can edit any properties common to the selected components as long as the property's value is not unique. For example, components in the 3D world cannot have the same name.
