vcProcessFlowGroupManager
The flow group manager is used to create, access and delete the process flow groups (vcProcessFlowGroup objects) within its owner vcProcessController.
| Controller | vcProcessController | R | Gets the process controller owner. |
| Groups | List of vcProcessFlowGroup | R | The list of all registered flow groups. |
| createGroup | vcProcessFlowGroup | String groupName | Tries to create a new group with the given name. The name must be unique within the process controller. |
| findGroup | vcProcessFlowGroup | String groupName | Gets a flow group with the given name. |
| deleteGroup | None | vcProcessFlowGroup group |
           Tries to delete the given group. Can not delete groups from different process controller. Note: Deleting a flow group also causes deletion of any contained product types and other tied data such as process flow sequence.  |
| deleteGroup | None | String groupName | Tries to find and delete a group with given name. |
| clearGroups | None | - | Deletes all groups. |
| moveProductType | None | vcProductType typeToMove, vcProcessFlowGroup destination | Tries to move the given product type to the given target group. |
| OnGroupAdded |
        Triggered when a new flow group has been added to this process controller. |
| OnGroupRemoving |
        Triggered when a flow group is being removed from this process controller. |
Examples
Example. Delete and define Flow Groups.
| from vcScript import * sim = getSimulation() process_controller = sim.ProcessController # Get the handle for product flow groups flow_grp_mgr = process_controller.FlowGroupManager flow_groups = flow_grp_mgr.Groups # Search for a given Flow Group # If Flow Group is found it is deleted flow_group1 = flow_grp_mgr.findGroup('Flow Group #1') if flow_group1: flow_grp_mgr.deleteGroup(flow_group1) # Define custom logic for when a new Flow Group is created def flow_group_created_handler(flow_group): print flow_group.Name, 'has been created.' flow_grp_mgr.OnGroupAdded = flow_group_created_handler  |
