Multipass weld
Create a root pass as a normal weld path or select existing weld statement from the Program editor as a root pass. Click Multipass from statements toolbar. This will open the Multipass user interface.
Multipass UI:
  • You can add and delete passes from bottom left corner.
  • Top left corner
    • a: a value (throat thickness) for simulation
    • α: angle between seam base and wall
    • Flip: Flip the corner orientation
  • In the multipass table, you can modify for every single pass: Layer, Base offset, Wall offset, Bisector offset, Wire offset, Wire angle, Speed, Start offset, End offset, Reverse direction and WPS
  • By clicking Reverse from the column headers, you can make every second pass to reverse direction.
  • At bottom in the middle, you can save the multipass templates.
    • Click plus icon to create new template and then set unique name for the template.
    • You can delete unused templates by clicking cross icon.
    • If you modify the template, save the changes by clicking save icon
  • Create the passes by clicking Generate
  • You can remove the created statements (for passes), by clicking Remove stmts
  • Note: operators +, -, * and / works in the fields
