WPS (Welding Procedure Specification) tab
Simulation parameters: Parameters for visualizing the welding during simulation.
Note: Modifying these parameters does not have affect to real robot program.
- Seam: parameters for weld seam visualization
- Weaving: parameters for simulating weaving
Process parameters: Set the welding parameters for the active weld. With many controllers, it’s a reference to some welding parameter table in robot controller.
- Speed: Welding speed in mm/s
- Process on: The values are called when the arc is turned on. The parameters in Process on include the Job no, weaving info etc.
- Process off: The values are called when arc is turned off
Create new row
Remove row
For a single Process parameter, you can also add list of possible Values by using the Add value option.
To remove the value, use the X option.
Further, the value can also be locked and unlocked.
