vcAssemblyPatternSlot
Assembly pattern slot defines a single location, including its position and orientation, in the assembly. Assembly slots are child objects of assembly patterns (vcAssemblyPattern).
| Properties | List of vcProperty | R | Property container. |
| OrderIndex | Integer | RW | Controls the order in which the pattern slots are created. |
| Position | vcMatrix | RW | Defines the positions of the slot within the pattern. |
| Pattern | vcAssemblyPattern | R | Defines the pattern that the slot is part of. |
| UniqueID | String | R | Unique identifier for the assembly pattern slot. |
| Item | vcAssemblyPatternItem | R | Defines the item that fills the assembly pattern slot in the assembly pattern. |
| deleteProperty | None | vcProperty property | Deletes a property of the step. |
| getProperty | vcProperty | String propertyName | Returns a property of the step. |
| createProperty | vcProperty | Enumeration type, String name, [Enumeration constraints] | Creates a new property to the step. See Property Constraint Constants for more information. |
| OnItemChanged | vcAssemblyPatternItem | Triggered when the item is replaced by another. |
