Align Components
A selected component can be aligned based on the position and/or orientation of two points in the 3D world.
  1. In the 3D world, select the components you want to align.
  2. On the Home tab, in the Tools group, click Align.
  3. In the Align task pane, edit one or more settings for picking the first point of alignment.
  4. In the 3D world, click a location.
  5. In the Align task pane, edit one or more settings for picking the second point of alignment.
  6. In the 3D world, point to a location to preview the effect the Align action will have on your selection.
  7. Click the location to align the selected component.
  8. Do one or more of the following:
    • If you want to exit the Align command, press ESC or in the Align task pane, click Close.
    • If you want to undo the effect of an Align action, on the QAT, click Undo.
    • If you want to redo the effect of an undone Align action, on the QAT, click Redo.
