Searching Component Data
At the top of each pane in the Component Graph panel are tools for searching and filtering data in a selected component.
- In the 3D world, select a component.
- Click the MODELING tab, and then in the Component Graph panel, do one of the following:
- To collapse everything in a tree, click the Collapse (MINUS SIGN) button.
- To expand everything in a tree, click the Expand (PLUS SIGN) button.
- To search for items in a tree, use the Search box. The Search box in the Component Node Tree can be used to search for nodes, behaviors and properties. The Search box in the Node Feature Tree can be used to search for features in a selected node.
- To show/hide all behaviors in the Component Node Tree, use the Behaviors check box.
- To show/hide all properties in the Component Node Tree, use the Properties check box.
