Transferring Components to Other Components
Behaviors that support material flow can be connected to transfer components from one component to another component by using interface type behaviors.
  1. In the 3D world, select a component.
  2. Click the MODELING tab, and then do one of the following:
    • To use an existing interface, in the Component Graph panel, Component Node Tree, select the interface you want to use for transferring components. Note that in most cases an interface needs to be disconnected in order to be edited.
    • To create a new interface, on the MODELING tab, in the Behavior group, click the Behavior arrow, and then under Interface, click the type of interface you want to use for transferring components.
  3. In the Properties panel, depending on the type of interface, do one of the following:
    • To use an existing section, expand the section you want or need to use in the interface. For example, in a One to Many Interface behavior you will need to use its only section.
    •  To add a new section (only applies to One to One Interface behavior), click Add new section.
  4. In the chosen section, do one of the following:
    • To use an existing Flow field, expand the Flow field you want to use in the section.
    • To add a new Flow field, click Add new field, and then click Flow.
  5. In the chosen Flow field, do all of the following:
    • In Container, click the behavior you want to use with the interface.
    • In Port, click the connector of the behavior referenced in Container that you want to use for the transfer.
  6. Make any other necessary adjustments to the interface.
