Doosan Connectivity Plugin
Installation
Visual Components installer contains all required components:
- Visual C++ 2010 redistributable package x64.
- Doosan Robotics API DLLs.
Requirements
Option 1 - connect to real controller: Visual Components Premium 4.9 Premium and Doosan robot.
Option 2 - connect to virtual controller: Visual Components Premium 4.9 Premium and DART Studio or DART Simulator.
Supported variables for pairing
The plugin supports the following read and write operations with the connected controller:
- Read joint values
- Read digital inputs
- Read and write digital outputs
- Read analog inputs
- Write analog outputs
- Read tool analog inputs
- Read tool digital inputs
- Read and write tool digital inputs
Virtual Controller
Virtual controller is included in Doosan DART Simulator and in DART Studio.
Virtual controller simulator can be run from inside DART Studio or separately as
C:\Program Files\Doosan Robotics\DART-Studio\Util\WinDRCF\DRCFWin32.exe |
Setup Server
Set Doosan Robotics controller IP address in the server setting panel.
Control Authority
On writing operations, access control is requested. Then, in another client program that currently has control authority, a query window pops up.
If you want to yield the authority, click the OK button and the authority is given to the requesting client.
Manuals
Link to manuals:
https://robotlab.doosanrobotics.com/en/Index
Note that registration is required.
