Release Notes 5.0.1
What's new in 5.0.1?
The Visual Components 5.0.1 update consists of improvements to many areas of the application, particularly in regards to stability and performance. The key improvements include:
Important to note:
- Related to change 45941, vcSingleDofLinkJoint.ValueExpression is no longer directly writable as a string. Update scripts to set the expression via the property value API.
Library Updates
44597 |
HOOPS Exchange 2026.2 update |
File type updates:
- ACIS up to 2025
- Autodesk RealDWG (AutoCAD) up to 2024
- Parasolid up to 38
- Revit up to 2026
- Solidworks up to 2026
- DGN 7, 8 (new file format)
Included fixes
General Improvements
43619 |
3D UI Pickable option for Collision Behavior Geometries |
General fixes
39839 |
Simplified Geometry is not hidden during path check |
42693 |
SetBase statement breaks after saving and loading layout |
44959 |
Regression: Software Rendering option missing in 5.0 products |
43711 |
Python 3 API: List property assignments trigger OnChanged event per item causing recursion depth errors |
42981 |
Startup Errors and multi-Instance Issues in VC due to unsupported external SQL Server Configuration |
45637 |
Articulated solver forward result invalid with coupled arm |
45941 |
vcSingleDofLinkJoint.ValueExpression returns a string |
45910 |
Robot position changed after switching selected robot |
45233 |
Delta kinematics produce unexpected behaviour |
46143 |
A link joint without assigned controller throws error. |
45648 |
Regression: ProductCreator Expressions are reset after layout is reloaded |
45586 |
Some undo actions produce unexpected behaviour when Jogging robots |
Included fixes for OLP
General Improvements and fixes
Features
42437 |
Improved active scope resolution for OLP statements. |
44102 |
Support for 4-axis TRTT workpiece positioner. |
44877 |
XML-import. Added an option to create custom properties for the statements. |
44056 |
Added API for custom path processes. |
44058 |
Added possibility to have units in process parameters. |
44233 |
Improved Via Solver to handling of system routines and Call statements. |
44687 |
Added External Axis Lock -statement support for Via Solver. |
39772 |
Added possibility to deactivate links from the Robot positioner calibration. |
40844 |
Added support for sequencing group statements. |
42374 |
Added API for creating Assembly Status statements. |
42446 |
Added a button for zooming in to selected statements. |
42447 |
Added an action for showing customizable labels for welds and searches. |
42900 |
Refresh search description if search linked to process path. |
43030 |
Changed the free path fanning to support snapping to surface. |
43099 |
Implemented IGM multilayer jog. |
43356 |
Added XML import startindex option. |
43411 |
Improved Approach and Departure point(s) generating for process paths in case of External TCP use case. |
43450 |
Added XML import option to use Faces to set Via path point orientation instead of WPR. |
44071 |
Improved TCP calibration results. |
Fixes
44948 |
Fixed autosearch functionality with welds created with old OLP versions. |
45487 |
Fixed a non-standard XML element before parsing the XML file created by Creo. |
46071 |
If WPS template is not given, use previously used template. |
45709 |
Fixed python error issue with Extras explode component function and Paint Add Nozzle function. |
42407 |
Fixed point level WPS for old statements. |
42415 |
Fixed AutoSearch WireSweep. |
42536 |
Fixed calibration panel routine names update, when routine names changed from Program panel. |
42745 |
Fixed some tooltips showing truncated text. |
42807 |
XML import search aux axis calculation fixed. |
43680 |
Fixed gantry calculation for ceiling mounted robots without Z axis. |
43690 |
Fixed "import as is" option for path conversion tool. |
44234 |
Fixed routine removed error in Robot Positioner calibration. |
44473 |
Fixed Path Setup creating too many undo/redo checkpoints for a single modification. |
Post Processors
Features
39867 |
Added support for: coupling23, Korean comments, LIN motion speed %, inline comments and accuracy value upload/download. |
43254 |
Implement WireSense SearchEdge and SenseL for ABB. |
43699 |
Cloos: Added possibility to upload and download point laser search program with CALL Proc command. |
44231 |
Four axis WPP (TRTT) upload and download. |
44533 |
Yaskawa: Possibility to upload and download global (shared) variables that are used for program synchronization (multirobot). |
42081 |
Yaskawa: Added new download property SearchResultRempVariableWS, which makes it possible to set different temp variable for wire sense than for normal search. |
35010 |
Yaskawa: Changed away from legacy behavior always forcing PL=0 for Process Start point. |
35650 |
Yaskawa: Automatic Weave Ref generating implemented for Robot as WPP use case. |
45044 |
Updated iLS-C support. |
30872 |
Universal Robots: Enable download and upload of statement acceleration control value for PtP and Linear motions. |
42316 |
Improved upload/download simulation compatibility for AccuracyValue (CNT) for Fanuc. |
42318 |
Improved upload/download simulation compatibility for AccuracyValue (PL) for Yaskawa. |
42410 |
Restricted changes to a component’s position or parent node during assembly when the component is locked, ensuring correct robot program operation after postprocessing. |
42947 |
Fanuc: Added ability to use multiple external TCPs and normal TCPs inside same program. |
43743 |
Hyundai: Added possibility to upload non-numeric IOs and inline comments in IO command lines. IOs uploaded as VerbatimComments. |
Fixes
45235 |
Fixed Mitsubishi configuration download/upload. |
45517 |
Omit NM from search block if no search Memory slot are given. |
45788 |
Fixed Fanuc DF search touch point had wrong coordinates. |
39084 |
ABB: Fix for download property Separate modules for subprograms. Only the subprograms that are called from main, are postprocessed as new modules. |
