Release Notes 5.1.1
What's new in 5.1.1?
Visual Components (VC) 5.1.1 introduces FactoryLens, which enables brand new workflows based on NVIDIA's Omniverse technology.
New features
FactoryLens
The FactoryLens is a new feature, which integrates NVIDIA's Omniverse technology into the Visual Components software suite, allowing users to visualize their layouts via a new high-fidelity rendering viewport.
FactoryLens includes:
  • High fidelity rendering viewport.
  • Video recording and Image export functionality.
  • USD Export.
Limitations:
  • Dynamic geometry updates are currently not supported, e.g. adding or deleting triangles, changing the position of vertexes, texture coordinates or Paint functionality.
  • First time launch may take longer than subsequent launches. This is due to the initial setup of the system.
  • Layout loading times are relative to the number of triangles present in a layout.
  • Point geometry is not supported.
  • Installation requires an internet connection.
Updates to Visual Components Platform
Bug fixes
46048
New Motion Controller: Copy-paste of statement with shared position creates a new local copy instead of referencing the same shared position.
46891
Python 3 collision detector exception with the new motion controller.
47849
Access Violation after Deleting a Joint (Old Controller).
48904
Program Editor loses active robot when a component is selected.
47441
PhysX results not deterministic in 5.1.
47972
Regression: PhysX illegal function call fetchResults.
39492
Unhandled error when deleting sequence with multiple editors open.
45487
Creo import - fix a creo xml bug before parsing.
48672
Py3 Application Script Update: cmdComponentPattern.py.
48552
Fixed issue, which caused Intune deployment to fail.
49075
Connectivity configuration is lost when saving layout in a version that does not have connectivity license.
Updates to Visual Components OLP
Features
49044
ABB - Add OmniCore search generation for SmarTac and WireSense instructions.
49402
Option to add manual robot positioner values from the XML-import.
49406
XML-import: Possibility to define statement specific robot and sequence.
49570
Added solver button to all hover panel presets.
49584
New Ref point type to Point control for IGM robots.
49749
XML-import for master-slave paths.
50338
Overlapping stitch welds now allowed.
Fixes
47298
Fixed Via Solver incorrectly solving enter and exit motions from system routines.
47980, 48567
Improved OLP active routine resolution to work better with custom program editors.
48052
Fixed pop-up ask for writing on main routine.
48921
Fix Postprocessing using OmniCore as controller write ArcL\on and ArcL\Off as primary - Support 5.1, and Fix support omnicore for ArcMoveL and MoveAbsJ statements.
49512
ABB Fix "SetBrush" statement upload.
49519
Fixed Fill Selected Statement causing errors with path statements that had no points.
50410
Flare point type fixed when used with stitch weld.
50567
Stitch Via Height minimum limited to 1 to avoid malformed paths.
50592
Zigzag tool skips creating empty paths.
