Release Notes 5.1
What's new in 5.1?
Visual Components (VC) 5.1 introduces a host of powerful features that gives users more tools and control over their simulations than ever before.
Important to note:
  • VC 5.1 does not require new product licenses. VC 5.0 product licenses can be used to activate the product.
  • The KUKA.Sim AddOn will not be available with the initial VC 5.1 release. It will be replaced by KUKA iiQWorks.Sim AddOn in a subsequent release.
Updates to Visual Components since the initial release (Updated 30/06/2026)
Bug fixes
47877
InvalidWrapperException on selection: property editor uses an invalidated rStatement wrapper
48015
Unhandled Exception After Clearing Layout with Output 81 Set to True in 5.1
48000
Random generator is not deterministic with the same seed
47813
Assembly slot properties are unavailable
47985
Deleting SetOutput statement causes exception
48015
47534
Application throws a Wrapper invalidated error when running layout
47489
vcWorld is not readable in a cloned component
Features
47685
Implement delayed calling of Python 3 OnFinalize() methods
47514
Python 3 - Modify default python script behavior snippet to no longer include getWorld() by default
New features
Updated physics engine
In VC 5.1, we have updated the underlying physics engine delivering major improvements to the physics simulation.
Improvements include:
  • Greater platform stability
  • Improved simulation predictability
  • Wider platform compatibility.
New navigation behavior
New navigation behavior in VC 5.1 enables users to build components and layouts that require accurate and complex path finding.
  • Environment-aware navigation that automatically respects factory geometry and obstacles.
  • Auto-generated navigation meshes leading to less manual path scripting.
  • Human agent, AGV and AMR behavior with reliable pathfinding and built-in avoidance.
  • Scalable multi-agent support for warehouse and plant-level mobile robot flows.
Italian, Portuguese and Vietnamese localization
The application user interface is now available also in Italian, Portuguese and Vietnamese.
Raycast sensor behavior improvements
Raycast Sensor now includes support for a Container Filter, allowing users to specify which components are detected instead of scanning the entire layout. This results in significantly improved simulation performance, especially in large layouts.
New connectors
Allen-Bradley PLC Connector
Connect to a Allen-Bradley controller during simulation and exchange data. Drive joint movements, read sensor values, and set outputs using a real or virtual controller.
Nachi Connector
Connect to a Nachi controller during simulation and exchange data. Drive joint movements, read sensor values, and set outputs using a real or virtual controller.
Epson Connector
Connect to a Epson controller during simulation and exchange data. Drive joint movements, read sensor values, and set outputs using a real or virtual controller.
Other improvements
Library Updates
46140
FFMPEG 8.1 update
43017
PhysX 5.5.0 update
Bug fixes
38502
Beckhoff ADS (TwinCAT) connection plugin depends on outdated ADS dll versions
38763
Custom properties values in RootFeature are not persisted
40553
Collision detectors are disabled if you save the layout while the Edit detectors panel is open
42047
Regression: Physics objects on wedge feature don't work properly
42693
SetBase statement breaks after saving and loading layout
43382
Regression: Python 2 vcApplication.addMenuButton() does not work in 5.0
43439
FBX record crashes the app
43538
Deleting a sub-layout leaves empty component group behind in Cell Graph
43694
Python3 vcCommand encoding issue when using non-ascii letters
43711
Python 3 API: List property assignments trigger OnChanged event per item causing recursion depth errors
46178
Py3: vcMessageService.Messages cannot be used
45404
Memory leak when using IDockAwareWindowManager to manage IDockableScreens
Visual Components OLP
Feature improvements
44955
Yaskawa: Fronius WireSense searches with macros
45515
OTC/Nachi: Added possibility upload and download linear speed as percent.
45957
Yaskawa: Improved circular search shift when there are opposing points on the search path
46036,
47042
Yaskawa: new laser searching and tracking functions with macro
Fixes
46071
If WPS template is not given, use previously used template.
46932
Importers fix for A-size is overwritten by template.
46965
Set 7th axis from the weld to auto search.
45416
Yaskawa: Fixed search C indexes when using macro parameter map and there are two reference points in macro job.
46246
Fixed undefined variable issues in TECHMAN writer.
47393
Yaskawa uploader: Fixed external axis values in situation where program uploaded to a robot with IO connected device(s).
