Release Notes 5.1
What's new in 5.1?
Visual Components (VC) 5.1 introduces a host of powerful features that gives users more tools and control over their simulations than ever before.
Important to note:
- VC 5.1 does not require new product licenses. VC 5.0 product licenses can be used to activate the product.
- The KUKA.Sim AddOn will not be available with the initial VC 5.1 release. It will be replaced by KUKA iiQWorks.Sim AddOn in a subsequent release.
Updates to Visual Components since the initial release (Updated 30/06/2026)
Bug fixes
47877 |
InvalidWrapperException on selection: property editor uses an invalidated rStatement wrapper |
48015 |
Unhandled Exception After Clearing Layout with Output 81 Set to True in 5.1 |
48000 |
Random generator is not deterministic with the same seed |
47813 |
Assembly slot properties are unavailable |
47985 |
Deleting SetOutput statement causes exception |
48015 |
Unhandled Exception After Clearing Layout with Output 81 Set to True |
47534 |
Application throws a Wrapper invalidated error when running layout |
47489 |
vcWorld is not readable in a cloned component |
Features
47685 |
Implement delayed calling of Python 3 OnFinalize() methods |
47514 |
Python 3 - Modify default python script behavior snippet to no longer include getWorld() by default |
New features
Updated physics engine
In VC 5.1, we have updated the underlying physics engine delivering major improvements to the physics simulation.
Improvements include:
- Greater platform stability
- Improved simulation predictability
- Wider platform compatibility.
New navigation behavior
New navigation behavior in VC 5.1 enables users to build components and layouts that require accurate and complex path finding.
- Environment-aware navigation that automatically respects factory geometry and obstacles.
- Auto-generated navigation meshes leading to less manual path scripting.
- Human agent, AGV and AMR behavior with reliable pathfinding and built-in avoidance.
- Scalable multi-agent support for warehouse and plant-level mobile robot flows.
Italian, Portuguese and Vietnamese localization
The application user interface is now available also in Italian, Portuguese and Vietnamese.
Raycast sensor behavior improvements
Raycast Sensor now includes support for a Container Filter, allowing users to specify which components are detected instead of scanning the entire layout. This results in significantly improved simulation performance, especially in large layouts.
New connectors
Allen-Bradley PLC Connector
Connect to a Allen-Bradley controller during simulation and exchange data. Drive joint movements, read sensor values, and set outputs using a real or virtual controller.
Nachi Connector
Connect to a Nachi controller during simulation and exchange data. Drive joint movements, read sensor values, and set outputs using a real or virtual controller.
Epson Connector
Connect to a Epson controller during simulation and exchange data. Drive joint movements, read sensor values, and set outputs using a real or virtual controller.
Other improvements
Library Updates
46140 |
FFMPEG 8.1 update |
43017 |
PhysX 5.5.0 update |
Bug fixes
38502 |
Beckhoff ADS (TwinCAT) connection plugin depends on outdated ADS dll versions |
38763 |
Custom properties values in RootFeature are not persisted |
40553 |
Collision detectors are disabled if you save the layout while the Edit detectors panel is open |
42047 |
Regression: Physics objects on wedge feature don't work properly |
42693 |
SetBase statement breaks after saving and loading layout |
43382 |
Regression: Python 2 vcApplication.addMenuButton() does not work in 5.0 |
43439 |
FBX record crashes the app |
43538 |
Deleting a sub-layout leaves empty component group behind in Cell Graph |
43694 |
Python3 vcCommand encoding issue when using non-ascii letters |
43711 |
Python 3 API: List property assignments trigger OnChanged event per item causing recursion depth errors |
46178 |
Py3: vcMessageService.Messages cannot be used |
45404 |
Memory leak when using IDockAwareWindowManager to manage IDockableScreens |
Visual Components OLP
Feature improvements
44955 |
Yaskawa: Fronius WireSense searches with macros |
45515 |
OTC/Nachi: Added possibility upload and download linear speed as percent. |
45957 |
Yaskawa: Improved circular search shift when there are opposing points on the search path |
46036, |
Yaskawa: new laser searching and tracking functions with macro |
Fixes
46071 |
If WPS template is not given, use previously used template. |
46932 |
Importers fix for A-size is overwritten by template. |
46965 |
Set 7th axis from the weld to auto search. |
45416 |
Yaskawa: Fixed search C indexes when using macro parameter map and there are two reference points in macro job. |
46246 |
Fixed undefined variable issues in TECHMAN writer. |
47393 |
Yaskawa uploader: Fixed external axis values in situation where program uploaded to a robot with IO connected device(s). |
