Release Notes 5.1.1
What's new in 5.1.1?
Visual Components (VC) 5.1.1 introduces FactoryLens, which enables brand new workflows based on NVIDIA's Omniverse technology.
New features
FactoryLens
The FactoryLens is a new feature, which integrates NVIDIA's Omniverse technology into the Visual Components software suite, allowing users to visualize their layouts via a new high-fidelity rendering viewport.
FactoryLens includes:
- High fidelity rendering viewport.
- Video recording and Image export functionality.
- USD Export.
Limitations:
- Dynamic geometry updates are currently not supported, e.g. adding or deleting triangles, changing the position of vertexes, texture coordinates or Paint functionality.
- First time launch may take longer than subsequent launches. This is due to the initial setup of the system.
- Layout loading times are relative to the number of triangles present in a layout.
- Point geometry is not supported.
- Installation requires an internet connection.
Updates to Visual Components Platform
Bug fixes
46048 |
New Motion Controller: Copy-paste of statement with shared position creates a new local copy instead of referencing the same shared position. |
46891 |
Python 3 collision detector exception with the new motion controller. |
47849 |
Access Violation after Deleting a Joint (Old Controller). |
48904 |
Program Editor loses active robot when a component is selected. |
47441 |
PhysX results not deterministic in 5.1. |
47972 |
Regression: PhysX illegal function call fetchResults. |
39492 |
Unhandled error when deleting sequence with multiple editors open. |
45487 |
Creo import - fix a creo xml bug before parsing. |
48672 |
Py3 Application Script Update: cmdComponentPattern.py. |
48552 |
Fixed issue, which caused Intune deployment to fail. |
49075 |
Connectivity configuration is lost when saving layout in a version that does not have connectivity license. |
Updates to Visual Components OLP
Features
49044 |
ABB - Add OmniCore search generation for SmarTac and WireSense instructions. |
49402 |
Option to add manual robot positioner values from the XML-import. |
49406 |
XML-import: Possibility to define statement specific robot and sequence. |
49570 |
Added solver button to all hover panel presets. |
49584 |
New Ref point type to Point control for IGM robots. |
49749 |
XML-import for master-slave paths. |
50338 |
Overlapping stitch welds now allowed. |
Fixes
47298 |
Fixed Via Solver incorrectly solving enter and exit motions from system routines. |
47980, 48567 |
Improved OLP active routine resolution to work better with custom program editors. |
48052 |
Fixed pop-up ask for writing on main routine. |
48921 |
Fix Postprocessing using OmniCore as controller write ArcL\on and ArcL\Off as primary - Support 5.1, and Fix support omnicore for ArcMoveL and MoveAbsJ statements. |
49512 |
ABB Fix "SetBrush" statement upload. |
49519 |
Fixed Fill Selected Statement causing errors with path statements that had no points. |
50410 |
Flare point type fixed when used with stitch weld. |
50567 |
Stitch Via Height minimum limited to 1 to avoid malformed paths. |
50592 |
Zigzag tool skips creating empty paths. |
