ROS2 bridge
The ROS2 bridge runs as a separate process and handles communication between Visual Components and ROS2.
ROS2 must be installed on the Windows computer running the bridge. The external ROS2 system can run on the same computer or another computer. When ROS2 runs on another computer, the ROS2 environments must be configured so that they can communicate with each other.
