Release Notes 5.2
What's new in 5.2?
In the Visual Components (VC) 5.2 platform, we are introducing AutoWeld, a brand new way to extend your simulation with PLC Logic Modeling, an expanded connectivity offering including ROS2 connection functionality.
Important to note
- iiQworks.Sim AddOn will not be available with the initial VC 5.2 release. The add-on is currently available for the VC 5.0 platform.
New features
AutoWeld
AutoWeld is a new feature available in all OLP products, which enables users to:
- Automate the path from welds to robot programs.
- Detect welds automatically and refine when needed.
- Generate robot-ready paths in minutes.
Logic Modelling (Early Access)
The new Logic Modeling feature introduces a new way to bridge the gap between simulation and PLC engineering within the Visual Components software.
Via the Logic modeling feature, we are introducing familiar IEC 61131-3 concepts such as:
- Function Blocks and Function Block Diagrams.
- Structured Text
ROS2 Connection
In the Visual Components 5.2 platform, users will have access to ROS2 Connectivity, which enables communication between Visual Components and ROS2 based systems. This feature allows simulation components to publish and subscribe to ROS2 topics, making it possible to connect to virtual robots with external robotics software, testing environments, and automation workflows.
ROS2 Connectivity can be used to:
- Send data from Visual Components to ROS2.
- Receive data from ROS2 into Visual Components.
- Control simulated AMRs and mobile platforms.
- Stream simulated sensor data to ROS2 applications.
New connectors
Hyundai Connector
Hyundai Connector: Connect to a Hyundai robot controller during simulation and exchange data with a real or virtual controller. Drive robot joint movements, read signal values, and set outputs directly from your Visual Components simulation.
Simit IPC Connector
Connect Visual Components to Siemens SIMIT running on the same PC and exchange signal values during simulation. Designed for high-performance communication and co-simulation, SIMIT IPC can exchange simulation data and synchronize simulation control between Visual Components and SIMIT.
Note: For remote connections such as connecting to Siemens SIMIT on a virtual machine, use the other SIMIT connector. The SIMIT IPC connector only supports localhost connection on same machine as Visual Components.
Other improvements
| 48321 | Added the MoveDrivers process statement for controlling motion-controller drivers. |
| 48322 | Added RunMotionRoutine to run a selected motion-controller routine synchronously. |
| 50077 | Added execution events to the Python 3 vcProcessExecutor API. |
| 49596 | Added Python 3 wrappers for LiDAR sensor classes. |
| 43571 | Added a Python API method to create a non-persistent collision detector. |
| 47591 | Added units to JointDriver expression properties. |
| 46145 | Added GPU acceleration for PhysX. |
| 46311 | Added support for additional physics geometry types. |
| 48697 | Displayed sub-assembly contents in the Assembly editor. |
| 48001 | Added the ability to update a Feeder’s assigned product. |
Bug fixes
| 51286 | Fixed a layout that could not be cleared after running AC Outdoor Assembly. |
| 51438 | Fixed layout-saving errors. |
| 52866 | Fixed a crash when saving a layout after deleting a component referenced by another component’s Python findComponent script. |
| 42731 | Fixed an exception when using Merge Faces on a primitive plane in Professional. |
| 47039 | Fixed an expression being deleted when another window or a dropdown menu is clicked. |
| 49904 | Fixed a crash when collapsing a Transform feature containing a Text feature. |
| 49948 | Fixed the disabled-but-visible Layout close button. |
| 49998 | Fixed an unhandled exception when closing an Assembly editor tab while FactoryLens is open. |
| 50405 | Fixed the Restore Windows option when resetting FactoryLens window |
| 50715 | Fixed the Coordinate UI not allowing component or feature X, Y, Z values to be zeroed. |
| 50991 | Fixed cloned conveyors sharing materials. |
| 51307 | Fixed user materials not loading correctly. |
| 51770 | Fixed the application getting stuck at startup when a plugin fails to load. |
| 34470 | Fixed an access violation when running a simulation with robot routines in Process Modeling. |
| 48077 | Fixed legacy eCatalog VCIDs not being found from an enabled source. |
| 48724 | Fixed E57 imports failing when file or folder names contain non-ASCII characters. |
| 48740 | Fixed dynamic components not being grabbable when a simulation is paused. |
| 50922 | Fixed an error when dragging a Motion Controller statement into a Group statement. |
| 50926 | Fixed an error when copying and pasting a statement that uses a shared position. |
| 51433 | Fixed a memory leak during long simulations. |
| 51785 | Fixed Python 3 robot-joint value writes becoming slower during an application session. |
Visual Components OLP
Features
| 49748 | Improved path import tool performance. |
| 50978 | Added support for RTR-style gantries. |
| 47021, 49130 | Added AutoWeld detection and automatic Arc OLP weld-path generation. |
| 49957 | Added optional paint consumption tracking. |
| 51013 | Allowed use of the HYUNDAI postprocessor with a connectivity license. |
| 52822 | Improved translations for the China-specific OLP AddOn. |
| 49517 | KUKA: Added upload support for classic and spline motion commands using KR C5 controller syntax. |
| 49572, 50610 | Added a HI6-supporting writer and uploader. |
| 44619 | Added support for palletizing robots. |
Fixes
| 50660 | Fixed re-creation of a deleted TorchCloud. |
| 51541 | Fixed Search Corner orientation when the wire roll is over 90 degrees. |
| 51582 | Removed unnecessary robot jumps during path creation. |
| 52382 | XML import: Fixed statement properties resetting when a statement is selected. |
| 52666 | XML import: Uploads to the selected sequence when the layout sequence is left empty. |
| 50577 | WPS rules: Start and end offsets are now applied only to cut-off points. |
| 51692 | WPS selector: Prioritizes reachable WPP orientations. |
| 52061 | Fixed WPP calibration when calibration points contain joints that are not present in the VC controller. |
| 52913 | Importers: Fixed setting layout default values when the layout is missing a default template. |
| 48866 | Python 2 and 3: Improved error messages. Opened source and DAT files are now closed when matching files are not found. |
| 49222 | Hyundai: Enabled accuracy value A=0. |
| 49223 | Hyundai: Process speed is now taken from point speed instead of being hardcoded. |
| 49224 | Hyundai: Removed the blank line after the robot language statement. |
| 49558 | ABB: Fixed postprocessing failure caused by a missing RAPID task in a multi-robot layout. |
| 50102 | Fixed issues with MacroCall upload. |
| 50129 | Fixed the untranslated ArcCommand property call path. |
| 51023 | Omron: Changed the VAR file to be global. |
| 51516 | Yaskawa: Removed the unwanted PTP statement at the beginning of upload. |
| 51694 | Fixed the path group closing tag. |
| 52750 | Fanuc: Added upload support for the “Robot workpiece positioner” category. |
