vcProductCreatorBatchMode
Configuration for batch feed mode in vcProductCreator. Creates batches of vcProductType instances in a sequence. Each batch defines the type of vcProduct to create, interval between instances and the maximum number of products to be created.
           BatchInterval  |
        Real | RW | Amount to delay between batches in seconds. Should be zero or greater. |
| Loop | Boolean | RW | Turns on/off the looping of the sequence. |
| ProductBatches | List of vcProductCreatorFeedBatch | R | List of all currently defined batches. |
| createBatch | vcProductCreatorFeedBatch | None | Creates a new batch with default values and adds to the end. |
| deleteBatch | None | vcProductCreatorFeedBatch batch | Deletes the given batch from this configuration. |
           getProperty  |
        vcProperty | String name | Returns a property matching a given name; otherwise returns None. |
           moveBatch  |
        None | vcProductCreatorFeedBatch batch, Integer index |
           Moves the given batch to the given index. The index must be greater than or equal to 0.  |
| OnBatchesChanged | vcProductCreatorBatchMode source |
           Triggered when the ProductBatches collection content has changed.  |
