vcSimInterfaceSection
vcSimInterfaceSection is a collection of connector fields in an interface.
| ConnectedToSection | vcSimInterfaceSection | R | Gets a section connected to the section.
           If section is not connected, value is None.  |
| Fields | List of vcSimInterfaceField | R | Gets a list of all fields in section. |
| Frame | vcFeature | RW | If belonging to physical interface, defines the Frame feature referenced as the location of section. |
| Index | Integer | RW | Defines the index of section in interface. |
| Interface | vcSimInterface | R | Gets the interface of section. |
| Name | String | RW | Defines the name of section. |
| createField | vcSimInterfaceField | Enumeration field, String name | Creates a new field of a given type and name in section, and then returns the new field.
           See Interface Constants for more information.  |
| deleteField | Boolean | Integer field_index | Deletes a field at a given index from the section.
           If deletion is successful, returns True; otherwise returns False.  |
