vcStatisticsDashboard
vcStatisticsDashboard is a dashboard used for visualizing and reporting statistics collected during a simulation.
Structure
The Statistics dashboard consists of tabs, which are of type vcStatisticsTab. Each tab contains a layout of one or more charts, which are of type vcStatisticsChart. Each chart uses a sampling interval to report one or more data series, which are of type vcStatisticsSeries.
Tips:
- Use vcStatisticsDashboard to create, select or delete tabs.
 - Use vcStatisticsTab to create, select or delete charts and define how charts are organized in a tab.
 - Use vcStatisticsChart to add, select, delete, clear or update data series as well as edit the position and attributes of a chart.
 - Use vcStatisticsSeries to define which property and from what components is reported in a chart.
| SelectedTab | vcStatisticsTab | RW | Defines the active tab in dashboard. |
| StatisticsInterval | Real | RW | Defines the global sampling interval for reporting data.
           This will affect data series referencing vcStatistics properties as well as any chart with a sampling interval of -1.  |
| Tabs | List of vcStatisticsTab | R | Gets a list of all tabs in dashboard. |
| createTab | vcStatisticsTab | String name, Boolean activate | Adds a new tab of a given name to the dashboard.
           The activate argument can be used to make the new tab the selected tab in dashboard.  |
| deleteTab | None | vcStatisticsTab | Removes a given tab from the dashboard. |
Examples
Example. Create new tab in dashboard
| from vcScript import * app = getApplication() dashboard = app.Dashboard tab = dashboard.createTab("Example", True)  |
