vcProductCreatorTableRow
Configuration for creating a single product instance at a specified simulation time in vcProductCreatorTableMode. Note that instances of this class are stand-alone objects, not wrappers for internal native objects, which means that modifying them will not change anything in vcProductCreatorTableMode.
Constructors
vcRobot is the object type used for programming a robot, its controller and executor with this library.
| new | vcProductCreatorTableRow | None | Creates a new vcProductCreatorTableRow object. The ProductType property must be set to make it valid. |
| ProductType | vcProductType | RW | The product type to instantiate. Value should not be None. |
| CreationTime | Real | RW | Simulation time in seconds when to create the product instance. Value must be greater than or equal to zero. |
