Start Transport In
A StartTransportIn statement allows you to start transporting one or more products instances into the process and to execute other statements while that is being done. This statement is typically used before a WaitTransport statement, with any number of other statements in between.
See the TransportIn statement for more information.
The source for the StartTransportIn statement is the Transport System (typically via Transport Link).
In Transport Products mode, all product transports will start at the same time.
In Process an Assembly mode, operations are performed in the same order as in the TransportIn statement.
| Name | Description |
Mode |
Defines how products are transported in. Transport Products Process an Assembly |
AssemblyOrderVariableName |
Name of the AssemblyOrder variable that defines which slots of the assembly will be filled, if they are currently empty. If left empty, all slots of the assembly will be filled. |
AssemblyVariableName |
Name of the Assembly Instance variable that will receive the Product Instance(s). Only one instance is processed - the type of this variable can be a list, but in that case the list may only contain a single item. If left empty, a new Assembly Instance is created. |
| ProductPositionFrame |
Frame location where the products are placed. |
| ProductVariableName |
Name of the variable where this statement stores either the product that was transported in or the assembly that was transported in or created. |
| ResourcePositionFrame |
Frame location where a resource will move while placing a product. |
| ReservedProductVariableName |
Product variable name defined in Reserve Statement. The variable can be a list. |
Product Filter |
SeeĀ Product Filtering |
