Test path
In Test Path section user can validate the weld path after the path is created and do the point modifications. The robot can be previewed in 3D window at every point in the welding path.
Name Description
1
Number of the path Number of the weld path.
2
Program status
Set the Program status, see Program Status for details.
3
Tool Solver
Automatically Adjust tool angles and offsets to avoid Robot Tool colliding with the Workpiece, keeping the path in Full-Modify mode. See Tool Solver for details.
4
Jump to first point
Jump to the first point in the welding path.
5
Jump to weld start
Jump to the point where welding starts.
6
Slider
Slider for navigating between points on welding path.
7
Name of the path Name of the weld path.
8
Current point
Current active point. The active point can be changed from dropdown menu OR by activating the field and scrolling with mouse scroll.
9
Undo / redo
Undo/redo option for path modification, allows to undo all changes that are done for the current path and redo all undone actions. Buttons become active after changes have been made to path or when an action is undone.
10
Path check
Open the path check panel, see Path check for details.
11
Point control
Opens point control window, see Point control for details.
12
Jump to last point
Jump to the last point in the welding path.
13
Jump to weld end
Jump to the point where welding ends.
14
Slider interpolator
Click the S option (turns blue) to jog robot with slider smoothly through the intermediate path between two points
Turn off the S option by clicking(turns grey) to jog robot with slider only from point to point and not in the intermediate path
15
Add point before
Add a new point before the current one.
16
Jump robot to point
Moves the robot at selected point in simulation window
17
Touch up
Touch up the current TCP position and orientation to active point. To move the point, jog the robot to desired position and do touch up.
18
Undo touch up
Undo the touch up at active point.
19
Delete point
Delete the active point
20
Full mode
Applies the path parameters to all the points in the path instantly when modified from the different tabs in the path setup.
Single mode
Applies path parameters to a selected point in the path.
Multi-mode
Applies path parameters to all the points in the path except the point which is modified with the single point change option
21
Add point after
Add a new point after the current one.
Note: Add or delete points or do touch ups only after you have modified all the settings at path setup tabs. Otherwise, modifying the settings after touch up, for example, rebuilds the path and deletes the point modifications (e.g. the touch up).
